Case Fans
  • Thread starter Thread starter kao
  • Start date Start date
kao
kao
7 Oct 2006
Essex
Could someone recommend some decent (quiet aswell!) 120mm fans and 92mm fans? One of the fans in my case has started to die and getting pretty loud so I thought I might as well replace all four.
Blue LEDs are also a plus. :p
Thanks in advance.
Yeah they're the ones I looked at, just wondered if anyone could point out if there's any better fans elsewhere =p
Not sure if they are available but the Antec fans that come in the Antec 900 case are pretty good, they come with a 3 speed switch so you can keep them quiet and have blue led's. If you have a fan controller the speed select switch would be pointless.
