Hi all, I'm after some case fans . I want these matching and they must be silent. Sizes are 2 80mms and a 120mm oh and pwms to. The case they are going into is a thermaltake v1. The 120mm is going on a corsair h55 the the 2 80mms will be exhaust.
The selection of 80mm isnt very wide,so it really hard to find matching fans that are available in 80mm and 120mm aswell as being PWM.Also as the 120mm is going on a radiator,so you also have to take into consideration getting a 120mm with decent Static pressure
hi and thanks for the reply. no they dont really need to match, they will be seen through the top window but no not matching really. the 120mm will be mounted for pull, there is a 200mm fan then the radiator.
