Hello,
I'm just after some advise of what would be a good set of case fans to use.
the case I am looking at is this one
http://www.overclockers.co.uk/showproduct.php?prodid=CA-161-NX&groupid=2362&catid=35
I shall be keeping the two fans that come with the case (back and top) but down the line I will be getting this AIO cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-025-CS
for the mean time I can fit two 120mm fans to the front of the case.
can anyone recommend some good case fans that are quite but have good air flow which I can then use on the AIO cooler as well later down the line?
thanks a lot
ED209
thanks a lot
ED209
