Case for £100 ... ?
P182 covers it all but the tray .it dont come out but with the great cable management it has it might as well have .simple it is to take the mobo out after a build with it.
Depends what you think looks good and the tray limits you a lot.
Thought about a well designed case so its easy to build in so the need for a tray is minimal?
Well it dont look to bad.I never brought my 182 for the look of it tbh but all the added features having not one cable over my mobo and how neat it looks makes it look that bit better.But indeed its not the best looking case i have seen.But for the money its a great buy.
like my antec 900, I sorted all the cables out before installing the board, so if I ever want to take out the board, it should slip out nice and easy.
