case for 100h or greater
12 May 2011
Southampton
I am thinking of getting a h100 or 110 or equivalent. But my shinobi doesn't fit a dual fan radiator so I am looking for a large case that does. I wanted a larger case anyway to help airflow etc anyway.
So please spec me a case for less than £100 that isn't butt ugly and has 120mm fan mounts with 15mm spacing for a 240mm radiator...
On that note, is the 15mm spacing between the top of the case and the motherboard, or is it the gap between the two fans / screwholes?
H100 fits in there easy
Moshi, would I have to have the top panel removed in order to accomodate the h100, or has top panel been removed in that pic so it is easier to see that the h100 fits in the top?
Personally i would choose the 500R as it has more flexibility with the removable HDD bays, more cooling options with mesh side etc...
They are very similar cases though so its really down to personal preference
