Case for 13" MBP
6 Oct 2004
England
Hi all,
I have had my 2010 13" MBP for about 2 months now and have been carrying it round in a rucksack :eek:! I think its about time I got myself a case.
I've looked around but I wanted to know what you lot would suggest as well!
Looking for something around £20-£25 so not too fancy, but I would like it to at least carry my external HDD in the case with it (Its a small passport sized HDD)
I got a neoprene sleeve which my Macbook fits into this means you can put it in any bag and can carry it around without it getting damaged, they're normally cheaper than a bag and it's really good :)
Hope this helps.
I too have the Incase Sleeve and love it, the inside lining is the softest thing ever :)
I would definitely recommend it if you can push for the extra expense over other cheaper sleeves.
There is a Diesel one in the Apple store that has a pocket in the front.
It's made of Denim! and the pocket is like a Jeans pocket lol
Whats the exterior like on the incase sleeve, is it soft and flimsy or does it have some rigidness to it?
I tried out loads of cases for the 13" MBP recently. Casecrown do one with a pocket which I kept and would suit you. Leather with memory foam inside (and inside the pocket too), has a handle which is useful and I definitely feel comfortable using it. You can get the power adaptor, mouse and HDD into the pocket if you need to though it doesn't look pretty because of the bulky UK plug.
