case for 2x 360 rads but not too big!
28 Jan 2015
Guys and Gals
anyone recommend a case that will fit a 360 rad in both top and front, as well as a pump/res combo XRES 100 I think it is and a couple of 3.5 + 2 2.5 drives that isn't huge and has good stealth- she- my youngest sister- is wanting me to build her a rig for her birthday-
Micro ATX mobo as well but happy to use a reasonable size case if it will hide as much as possible
BUdget upto £200 ish but any penny saved will be used to upgrade other things
Thank you for any suggestions:D
system is a 6700k with GTX Titan X, overclocked of course, on a Z170m Mortar mobo, 16GB Corsair Ram I think- it's her current rig but she has an AIO cooler on the cpu and nothing on the Titan yet
Looking to get a black case with all black fittings- she loves AC/DC and Back in Black being her fav album
not many 'stealthy' small cases about that will take 2 x 360s I dont think.
Maybe take a look at Thermaltakes CoreX9 cube or the cheaper core X2.
Bit OTT 2 360's to cool this, you could go for this. With Glass or alloy sides.
https://www.overclockers.co.uk/phanteks-enthoo-evolv-atx-glass-mid-tower-case-black-ca-054-pt.html
I think the Define S gives more options as it can fit all the SDD/HDD at the rear and give enough room for a 360 rad in the front and leave the bottom mounting point for the pump & reservoir
Only thing I don't like is that there is no psu shroud so might have to get inventive with something
