Case for 7950GX2 card
4 Nov 2004
I'm about to built a new system and want to use a 7950GX2 card.
Obviously its a long beast (the card) and need a case that it will fit in.
Does anyone have any suggestions?
Rich
It should fit in any Normal sized ATX case, and ofcourse anything evn bigger than that.
If you want plenty of space around it the Akasa Eclipse would be ideal.
Almost all cases will hold that card, if not all of them. :p
Care to choose a few you like the look of from OcUK's range and we can go from there? :)
I suggest the Silverstone Temjin TJ07 (black) (i want this case so much) or the Lian-Li PC V1000+ (silver).
TJ07 is really expensive for what it is though.
Anything from the PC7+ would be a good option.
And the Lian Li desks start from £1500 and go a lot higher.
Good choice :) , I'm really happy with mine and cant see myself ever changing to another case, unless another form factor comes along and I'm forced to.
Mark
PyroboyUK said:
For me it would have to be the Lian Li V1000+. Its had so many great reviews!
If you take build quality out of the equation the Eclipse is actually the better case, better cooling and more space for hard drives with a modular PSU (but dont get me started on using modular PSUs with 5 hard drives).
Add in build quality and looks, then yes the v1000+ is the better case for me, but however you put it the Eclipse is in a different league for cooling. :p
Hi guys,
got the case now and its very impressive.
Thanks again for the suggestions.
Only problem is that Im not used to a case being so open upable if that makes sense. Took a few too many of the screws out first time round :)
