- 17 Sep 2007
- West Yorkshire / Market Bosworth
i have to find a case , preferably under £80 for a build im doing for my friend. has to fit a arctic cooling freezer pro, atx mobo, enough room for a 8800gts 512mb , only two hard drives are going to be used and two dvd rw drives, so hopefully these will fit. the case needs to have good air cooling and good looks (preferably black with a window), also preferably easy to use (internally) so im talking taking out cages and fitting stuff etc.
what do you guys recommend:
i was thinking of :
antec 900, lian li pc7, nzxt lexa or i might be able to bump the budget up to a Akasa Eclipse 62.
anything else worth considering?
i was thinking of :
