Case for a future project
6 Aug 2010
Birmingham
Hi all
Looking at doing my next project which I am going to need large amounts of radiator space as I am looking to watercool everything I can. I was looking at the silverstone tj07 but projects on them have been a bit done to death so is there any alternatives?
So looking for a case to fit a lot of rad space internally, maybe even 1 or 2 loops for around £250 - £300 max and preferably with I/O shield on the back - is there anything else but the tj07?
Greboth.
Hmmm will have to do some reading on them, I dismissed them early on due to only being able to fit a triple rad in but I have just been looking at a modded 800d to fit a double in the bottom area.
Due to the all the heat and wanting to keep it quiet the more rad space better and as far I see it, it's like this
800D: 120.3 roof and with modding a 120.2 in the lower compartment
tj07 moving hdd's to drive bays: 140.4 and 140.2 in the bottom and with some more modding a double in the roof (not sure if a 140.2 would fit or just a 120.2)
Starting to be resigned to having to go with the tj07 as can't find anything that can compete on rad space in my budget :(
You can also mod the ATCS 840 to fit double rad in the bottom theres a vid on you tube about it. What about the Lian Li P80 case also plenty of room in there for rads at the top and front.
The Lian-Li PC-A7xxx series are very good cases. Brilliant build quality, huge amounts of space, and they look great.
The Lian Li full towers which have the HD racks at the bottom can be modded to fit 2 x 360 rads (pull only, thin radiators).
