Hi,
in my quest to build a near silent pc I have purchased a Gigabyte 9800GT Silent Cell GPU, but it measures at around 26.5cm.
I am now looking for a decent case that would big enough to house the card but that needs to have good sound dampening and as few fans as possible, edit: while staying reasonably cool.
Most of the time the pc will be used for web browsing, programming etc etc but there will be some gaming.
CPU will likely be a Phenom II 905e (TWP @ 65W) though in the future I may upgrade to a 955BE or faster depending on what's available at the time.
I had considered a Lian-Li PC-B25B which, at £154.99, is about as much as I'd like to spend but would consider paying more if suitably justified
From what I've read it should just about fit the gpu in.
Any suggestions?
Thanks
From what I've read it should just about fit the gpu in.Any suggestions?
Thanks
