case for gaming pc
5 Mar 2006
mansfield
Hey guys i have around £70 for a case needs to be quiet and have a psu (430 watt min) maybe not included but have link to go add to it , not botherd about lights n stuff just a nice cool quiet case.
Cheers guys please post links and makes / models
Can not post links to competitors, but for that money a Antec with integrated PSU would be ideal, like the sonata 2.
Good case for the money with a really good PSU.
Ahh much clearer when you put it like that :p
Taking the around to mean you could go to £77.
From OcUK and basically anywhere for that money, the best bundle of the two you can get is the Sonata II FROM THIS OCUK PAGE :D
It is one of if not the quietest case you can get, and it cools ok to :)
The psu is a good solid Antec one, no faults there either.
Just looks a bit bland, but both for £70 there will be a compromise somewhere.
Ye thats the 1 i was looking at :) But as most of the fans say (optinol) or *** ever does that mean they are not included but able to put them in or coem with it just not installed?
One fan comes with it, the optionals list the places where if you purchased another fan you could fit it :)
So which do you think i should add and where? i have around £14 for soem extra cooling nice and quiet remeber but good cooling?
Well get one more akasa amber 120mm fan, Akasa AK-183-L2B Ultra Quiet 120mm Fan - 3 pin (FG-024-AK)
That will take up the optional 120mm slot and double the cooling potential of the case :)
ye that sounds good as will have the freezer pro on the cpu so no need there and the 80mm will probs be a add on pci card to cool the gfx so no need there, agree?
