Case for H100i P/?
13 Nov 2013
London
Hi,
My current case (storm trooper) doesn't allow me to go P/P with H100i. Any ideas for £170? Will have SLI/CF next month so i need good airflow, would love to hide SSD and HDD behind the motherboard to keep it clean. Was looking at the NZXT H630 as its a quiet and elegant case, any other ideas?
Push/pull wont give you enough air flow to give a temperature difference inside your case but if you are after something with a lot of room and to look neat with a ton of air flow, then the Corsair 540 is a good bet! It comes with 3 of the best case fans available (AFs 140) and SSD/HDDs are mounted behind the motherboard above the PSU.
For SLI/Crossfire on air coolers, i would say that there are few cases better, considering how small the case is and also how cheap it is.
i know about the 540 and HAF but those cases are not to my taste. If i get something with enough room behind i can make something to mount SSD/HDD. Was looking at the 750d on the forum and you can drive bay and install hdd/ssd there. 750D is a good looking case.
750D would be my choice based on what you just said.
- You can vertically mount your SSD at the back.
- Remove the HDD bays and mount HDD's in the 5.25" bays instead to increase airflow through the front.
- There is more than enough room for a H100i/110 in push pull configeration at the top of the case.
- Lots of options for future water cooling
- And by far the best case in terms of build quality i have ever had the pleasure to work with.
Quality on the Obsidian series is well worth the price premium and then some IMO. They all have a steel frame and aluminium casing. They are heavy but I expect my 650D would protect me from an explosion, if it occurred inside my PC :D
Just put the case on gumtree, will see how it will go.
How much should i ask for it ? Have extra window side panel for it.
