Case for lots of HDDs?
29 Jul 2004
Esher
Hi All,
I'm just planning a build at the moment, and it's main usage will be data storage.
Essentially I'd need around 20 tb of storage, with room to expand.
The BitFenix Shinobi XL Full Tower seems like the best option as I can use the 7 3.5" bays and then use the 5" bays as well.
Any better cases out there?
corsair 750d can hold 6 3.5 drives plus 4 ssd's, what would be great though is if corsair would sell the drive cages then you could fir 9 3.5" drives
Lian Li - can potentially hold 30x3.5 or 36+ if you mix 2.5 and 3.5 :)
Although something like a san storage array may be a better way to go
Corsair 750D/900D, nice and BIG :D
I'm guessing you're going to go with like 10 x 2TB drives or something?
I have the Corsair 900D and can recommend it for what you intend - there's room for 15 hard drive bays so should definitely be plentiful for 20-30TB of storage. In-fact, if you buy 4TB HDDs then you could have 60TB of storage if you really wanted!
