Case for New Build
23 Aug 2011
Kent
Hi all, I'm trying to decide on a case for a new build that I'm doing for my dad.
It's going to be used for business so I want it to look professional and sleek. A couple of options I've seen so far are:
Aerocool Vs-9 Advance Midi Tower Case - Black
http://www.overclockers.co.uk/showproduct.php?prodid=CA-015-AE&groupid=2362&catid=2277
Anidees AI-6B Midi Tower Case - Black
http://www.overclockers.co.uk/showproduct.php?prodid=CA-006-AD
Corsair Obsidian 550D Quiet Midi Tower Case - Black
http://www.overclockers.co.uk/showproduct.php?prodid=CA-064-CS
Main things I want from the case are:
  • It has to look and feel sturdy
  • It has to look professional
  • Needs room for 2 DVD RW drives
  • Needs to have SSD support
  • A couple of USB 3.0 ports at the front would be nice
The Mobo is ATX.
Does anyone know of a case that fits the bill? I quite like the ones I've listed but having a second person tell me they look good would be reassuring :)
330R: http://www.overclockers.co.uk/showproduct.php?prodid=CA-144-CS
the 330r is a silent sleek case.
200R (though its out of stock): http://www.overclockers.co.uk/showproduct.php?prodid=CA-107-CA
Either of those for me! :)
I prefer 330R out of the two you suggested but if you had the extra £30-40 to spend wouldn't you go for the 550D that I linked?
It looks sturdier and comes with 3 fans built in. Also sounds as though another 240mm fan can be attached to the top vent although I'm not certain because of the wording. What do you think?
