Case for top mounting 360mm with good airflow
1 Jul 2011
Planning my new build around an RTX3080 I was going to mount the 360mm radiator on the front but on finding out that the 3080s are not blower type it look like it would be better to have it on top with a good fan setup front to back to keep the interior cool.
I am having trouble finding a case under £100 with good ventilation out of the box without changing the fans that will take a 360mm radiator on top.
any ideas Thanks
Its looks like I will have to spend a bit more than £100 to get what I want
Does anyone one have a case that has room for a 360mm radiator and a 3080 and has good airflow
I don't own either but am looking at the Phanteks P600S, which is just over budget.
Or the P500 which is under £100 for the non-RGB version.
Both are decent air cooling and can take 360 top mounted rads.
Thanks for the reply, I will have a look at them
They look ideal
