Case for two 120.3 rads
23 Feb 2009
Hi,
I am currently using the P182 case. I have a 120.3 radiator attached to the back, which i think looks kinda cool. I am happy with my current temps, however im looking at getting another gfx card for sli. I will be needing more radiator, so was thinking may aswell get another 120.3.
Looking at the interior of my case it looks like the only place i can fit another rad is in the roof. It looks like i will have some cutting work. Not ideal for a couple of reasons.
So i was wondering if there is another case out there with the same look as the p182. I need one with room in the roof for a 120.3 rad without cutting the case aswell as having watercooling holes pre drilled to the outside, so i can hang a 2nd 120.3 from the back via radbox?
Thanks in advance,
Phil.
Lian Li PC-9B is about the closest you're getting to the P182 case... Unless you get a 2nd hand Lian Li V series (which are a lot bigger)
