Case for watercooling ?
tj07 owner and i love them but as said
triple rad fits easily in bottom, completely isolated from main section, some builds have triple rad AND double rad in bottom. could also put a double rad in the top with minimal modding
if too much £££, then lian li!
get a secondhand TJ07 off the bay or MM. You cant really get much better for watercooling for £200 unless you want a Banchetto 101 :)
I'd have to agree with mike although i don't think they're as pretty as Lian Li's and Silverstones.
They're big but do a very good job. I use one of their smaller cases the H2g0 and have found it cools a high end system very well indeed. Mine consists of a watercooled quad and northbridge (using one PA120.2) and a GTX260 (used to have crossfired 4850's). The case can accomodate 2x PA120.2's and 2x PA120.1's if needed so there's a lot of cooling potential in a fairly compact case.
Click on the details below my sig picture (orange text) to see the case.
gt
decided yo buy tj07 + window black just need to find i guess different retailer ocuk out of stock and bit over price
