- 17 Jun 2011
- Suffolk, UK
Hello all,
I've recently bought a new system:-
ASUS maximus IV
Intel 2600k
Corsair xms3 1600mhz
Corsair A50 cooler
Palit 580GTX 3gb
2x 600gb Velociraptors (in raid)
Already owned:-
galaxy 1000w PSU
Pioneer BDP
WD 1tb green
Lian-Li full tower (not sure of model but a good 6-7 years old) fans: 2X 80mm in & 2X 80mm exhaust
Other than the GFX and raptors this was bought as a preclocked (@4.6) kit from OCUK which was fully tested in shop.
I've been noticing quite a lot of graphical artifacts in game and since the weathers warmed up BFBC2 has started crashing after 1/2hrs play. The amount of heat kicked out the back in game is quite substantial (sitting in underpants sweating type substantial)
So I started looking into system temps and voltages:
Voltages seemed ok, very little variation.
I found my temps were getting fairly high, but nothing compared to my old 280gtx. Peak 80deg C but averaging 75deg C, compared to the 280 which peaked at over 90.
CPU temps were about 70deg during OCCT stress test (but no failures), not sure if this is normal, but just as a comparison i reverted back to the standard unclocked bios settings and those temps dropped to 50ish.
I have installed evga precision and played with the fan speeds, have taken the side off the case for extra air and re-clocked it back to the OC of 4.6ghz, it's now sitting stable @65 deg with the fan running @75% in game although I still get the odd graphical glitch it's probably just BBFC2.
So I'm happy its a cooling issue.
Now my question is what do you reckon my next step should be?
The old lian-li case is very good but the cooling opportunities are limited, there is space for 2 more 80mm exhaust fans above the PSU but thats it. the top and side panels are solid but i could probably cut new 140mm holes to fit extra fans, but i cant see me making a very professional job of cutting bloody great big holes in my case.
The second option is a new air cooled case NZXT phantom looks good (although I'm open to other choices), with the extra fans fitted I think it should give a sufficiently good throughput of air.
And my last option is keep the Lian-Li and go the water-cooling route, but i have absolutely no experience of doing this.
Although the money isn't overly important I don't want to be wasting money on things i wont see the full potential of. But on the other hand if I'm going to get significant cooling gains and/or it will make it significantly quieter then I'm happy spend the extra.
Sorry for the long post, but any help and opinions would be greatly appreciated. I've built loads of system in the past for me and mates but never really overclocked anything so its all a learning experience for me.
Thanks again,
Jim
ASUS maximus IV
Intel 2600k
Corsair A50 cooler
Palit 580GTX 3gb
Already owned:-
galaxy 1000w PSU
Pioneer BDP
WD 1tb green
Thanks again,
Jim
