Case Help/Advice.
21 Nov 2004
Glasgow, Scotland
Hi
I currently have A Chieftec MA-01 WD white full tower case, which has housed my last 3 PC builds (including this one) but I'm not sure its suitable any more as I can't fit my lower drive cage (thanks to massive 3870x2) Basically I'm after a bigger (!) or at least better laid out case. I built a system for a friend based on a Thermaltake something or other (yeah great aren't I - cant remember) and I like the idea of screwless drive fittings. Also all my drives are white/grey, and all I seem to see is black cases :(
budget is £100 or less if possible but may be able to stretch.... any ideas/suggestions ?
Also weight is an issue, I'd rather not give myself a hernia whilst trying to lift it with all the bits in (although I know full towers will be a bit on the weighty side)
cheers
Andrew
Ordered antec and a few other bits... credit card is going to love me... not :eek:
