Right straight to the point. I want a HUGGGEEEEE CASE what will be future proof for under £140.
I have a nivida 275GTX, Asus P5Q Deluxe Intel P45 MB, 1 Western Digital Caviar Blue 500GB, Intel Core 2 Quad Q6700 LGA775, power supply not got yet, if i get recommended a coolmaster ill end up getting a coolmaster power supply to be sure it will fit. Other small things i will by according to the case.
remember i want this HUUUUUUGGGGGGEEEEEEEEE a lot bigger than HUGE! and under £140 and i want decent air flow to, i dont wanna be cutting holes in the side panel and adding 120mm fans again like what i had to do with my old branded pc
[edit] may be planning to run SLI in future or crossfire [end of edit]
