- 25 Nov 2011
- Cumbria, United Kingdom
Need to go small on my build due to space constraints. Only running one gpu and an overclocked 2500k with 2 ssds and a hdd.
Need a case around the same size as the bitfenix prodigy, is there any matx cases arouns this size? I know it can be done because the prodigy with mods can fit matx boards in but.
Im just debating as the p8z77i deluxe is 40 pounds more than the asus maximus gene v is available for. Which route should i take? If its matx i need recommendations for a small case that supports long gpu's like a 7950 and gtx 480 etc. Thanks
