Ok, I've jus put together a nice spec computer, and I am on the verge of buying it, but I can't decide on which case to get. I've had my eye on the Coolermaster RC-1100 Cosmos S, or the Coolermaster HAF 932 which in my opinion are stunning, but I think they will be way too big, and basically look empty. Any recommendations?
Gigabyte GA-MA790XT-UD4P (Socket AM3) PCI-Express DDR3 Motherboard
AMD Phenom II X3 Tri Core 720 Black Edition 2.8GHz (Socket AM3) - Retail
Corsair XMS3 4GB (2x2GB) DDR3 10666C9 1333MHz TwinX Dual Channel (TW3X4G1333C9)
XFX ATI Radeon HD 4890 1GB GDDR5 PCI-Express Graphics Card - Inc. Tom Clancy's H.A.W.X & BattleForge
Corsair VX 550W ATX Power Supply (CMPSU-550VXUK)
Western Digital Caviar Black 500GB SATA-II 32MB Cache - OEM (WD5001AALS)Samsung SH-S223F/BEBE 22x DVD±RW SATA Dual Layer ReWriter (Black) - OEM
Sunbeam Core Contact Freezer CPU Cooler (Socket 754/939/940/AM2/AM3/LGA775)
Let me know what you think about the above two cases in terms of size of the build, and if you do think they would look practically empty, suggest what case you would use. In fact, suggest what you would use anyway, I'm quite interested.
P.S. Budget is about £150.00, but I would much perfer spending about £100, the extra £50 would be for something that made my heart stop. =)
