Case help
31 Dec 2003
Midlands
Hi all
After my recent shopping trip to overclockers for a dell 2408 monitor and a lower profile ati 4550 to go into my HP DC7000 SFF I have found a little issue.
Unfortunately its advertised on the OC website as DUAL DVI / HDMI but when you put on the low profile card slot you only end up with one DVI and I want to run dual monitors with extended desktop.
I want to know if it is possible to take out my motherboard etc in y HP DC7700 SFF and buy another small tower for this to go into so I dont have to use the low riser extention and therefore giving me an additional VGA connection to enable me to do extended desktop
If so which case do you recommend, I dont want to spend a fortune.
Cheers
Baz
