Hi
Thanks for those Case details
Do like the Phanteks Enthoo Pro M Acrylic and None Acrylic but it says on the spec sheet E-ATX *(up to 264mm wide), ATX, Micro ATX, Mini ITX
My Motherboard is 269.24mm long 12" x 10.6" ... so I assume it wont fit
For the NZXT Source 530 it says ITX, Micro-ATX, ATX, EATX (322x272mm) so this one will fit....Would prefer the Phanteks as its better looking...
Is there any other options as I could increase my budget slightly
