Case help!
29 Nov 2002
Midlands. UK
I have a PC I use as a server it has a full ATX mobo / PSU and 4 * 3.5” HDD and not much else .. I’d like a case to house it all that’s as small and compact as possible ..
All I can find is large cases with space for expansion cards etc that I simply don’t need?
Does anyone know of any cases that might suite this purpose?
Quick google suggests: Cooler Master HAF XB EVO.
Requirement to be ATX and support 4x3.5 drives does limit the options somewhat, ideally downsizing to a smaller form factor and/or migrating to a lesser number of drives would make your options much wider. Small and compact isn't typically how you'd describe an ATX system (at least not one housing 4 full size HDDs - switching over to SSDs would also broaden options).
