- 6 May 2009
Hi,
I have a 200mm intake fan that is part of my case at the front of my pc (details below for all hardware involved) and for some reason, as of late, it doesn't not spin when I turn my pc on. I actually have to physically give it an initial light spin with my hand and then in kicks in.
I've checked the cable connection from it to the motherboard and it's fine. It also shows up as connected in the system BIOS.
I can only guess that for some reason it isn't getting the initial jolt of electricity when the pc is turned on to get it going, but it's obviously getting sufficient power to spin continuously after I give it a helping hand and does so until I turn the pc off. It also increases/decreases in RPM no bother when I adjust its speeds in the BIOS via the fan monitoring section.
I've made no changes to the BIOS settings or hardware on the pc so I am at a complete loss as to why its started doing this. I suspected a burnt out motor but that can't be the case if it is able to spin normally after my intervention....
Does anyone know what may be the problem and what I can do to fix it? As it stands I have to take the front panel of my pc and give it a spin every time I turn it on, which isn't massively annoying but obviously it shouldn't be doing this
I use an MSI motherboard, so its their BIOS software.
Case:
Phanteks Evolv ITX Mini-Tower
Fan:
Phanteks ph-f200sp PC Housing Fan (I think it's this one, it came with the case).
Cheers!
Case:
Fan:
Cheers!
