fans its impossible to choose for some1
i stick with noctua mostly, their new pwn fans are great
if you want super cheap tho can recommend the arctic cooling pwn, u dont get much cheaper and they pretty good!
the corsair above are inbetween the 2 for price atleast
The airflow is quiet adequate on these fans. I have 3 as intake on my rig (2 front, 1 floor) and even at 800rpm they shift a fair bit of air.
Obviously it' dependent on case but surmising an average case has a volume of 10 cubic feet then 1 fan being able to move 39 cf in a minute means it's moving 3.9 times the amount of air that can be inside the case.
It's not as straight forward as that but it's the general jist.
I recently bought some 120mm Noise Blockers, brilliant fans, nice and quiet, came with silicone mounts/grommets and two lengths of cable depending on your needs
