Case Lighting Recommendations
  • Thread starter Thread starter Deleted member 2277
  • Start date Start date
Ive used NZXT braided LED lighting strips in my past two builds (a 2M blue one and a 2M white one). They are great, but the adhesive pads could be a little better. :)
Used the bitfenix alchemy strips on a build before which gave nice even lighting uses some good 3M adhesive on the back so no fear of it coming unstuck.
Thanks for the replies, Will I be able to get away with using one vegas strip in an R4 case or will I need two?
I went with the Akasa Vega strip in blue, fitted to the front side of the case so that the LED's can't be seen from the outside, it provides good even lighting. I'm very pleased with it, it appears to be good quality. I'm not sure how the more expensive ones could be any better.
