Case lighting, will the colours mix?
Caporegime
29 Jul 2011
In acme's chair.
I kinda want to replace my front and top fans with Aerocool Shark Evil Orange LED fans, and i also want to fit white cathodes on the inside of the case, and orange braided cables.
Will the orange bland with the white making the glow from the side window a sort of anaemic peach colour?
I really want the inside to be lighted white showing off the orange braided cables, but i want orange glow from the top and front...
Thoughts?
Or maybe i should just get white braided cables and either blue cathodes or white (if the colour will mix into a lighter blue)
Personally I think the White & Blue sounds a lot better than the White & Orange to be
honest with you.
The White will shine out of the side panel and the blue will shine out the front and top of
the case is that your idea?
As well as going with your coloured braided cables?
honest with you.
thats the idea :)
Blue fans, white cathodes, white braided cables, white mouse and keyboard backlighting, white bias lighting behind the monitor, dark room.
Sounds Cool m8, although all the White might be a bit of a muchness, Well it would for
me anyway I would probably have a different colour behind my monitor but its your setup
dude, You could go with the Orange behind you monitor then you have the best of all
worlds then as well you have your White & Blue inside the case and your Orange behind
the monitor, I bet White would bit a bit harsh on the eyes in a dark room were as Orange
would be that bit calmer.
It is only a dim LED strip to make a nice glow up the wall :p
I might just get blue LED strips for inside the chassis, that way they wont be so bright but still enough to light it up that little bit more, like i want.
