Case Lighting
12 Jan 2011
Hi, I found on the Corsair web page that whey gonna sell new version of 600T Graphite - windowed >> click << (I hope OC is going to sell them in white and black option). But I wanna have nice cold blue light inside with the option to shut it down (light). I found
http://www.overclockers.co.uk/showproduct.php?prodid=BB-007-SY
but I will have 2 controlers for fans (1 from the case and panel wil be the 2nd) and only 1 will be working.
So i decided to not use LED fans and use LED strips + white clear fans ( maybe top 200mm -> 2x 120mm blue LED fans). Does the LED strips have any switch where I could get them off ? Or just the Cathodes have some ? How does it looks like with bouth of them ? I expect from the light stuff to be very nice and the cooling quiet as possible if not needed that much.
http://www.overclockers.co.uk/showproduct.php?prodid=FG-045-AK&groupid=701&catid=57&subcat=4
http://www.overclockers.co.uk/showproduct.php?prodid=FG-050-AK&groupid=701&catid=57&subcat=4
LED strips tend to be wired direct to PSU via Molex (or just bare wire if you go to eBay) but that doesn't mean you can't wire a switch in there yourself.
