Case making expanding noises?
13 Jan 2012
United Kingdom
hey guys, i recently switched my pc from a storm trooper to a enthoo luxe
Now note my cable management wasnt the best but my case makes clicking and tapping noises when ever it gets heated up, for example when i play a game it will make noises
is this due to my bad cable management or is the case truly expanding slightly under heat?
it must be, i keep my pc off all day when at work and due to winter it gets very cold
then i come home and turn pc on, it instantly starts making ticking and tapping noises then after a while they stop (bear in mind i got a 290x in here)
then when i switch my pc off the noises start again for a while then stop
is there anything i need to be concerned about?
My Lian Li case does the exact same thing, and my Coolermaster before that. You can reduce the expanding sound slightly by using noise dampening foam, and using screws like these.
My primo is the same, probably the plastic parts on it. Never had this with my lian Li A70f as there were no plastic parts on the frame.
Yeah i think its the plastic, my case does it when its got the front panels on, but i never noticed it with it stripped down to the metal, both my TV and IPS monitor also does the same, but my TN doesnt as i guess it doesnt get warm.
