- 17 Sep 2011
- In my PC
Hi guys ,seems my working pc only worked one day and now i got the same problem with the position of my graphics card effecting the stability of my system that i had before i replaced the motherboard....
I've had a right good look in the case and to me it looks like the graphics card slopes down a little from the end where the DVI ports are towards the back of the card. I've seen this before and never had stability issues with it! Everyone knows when you build a system outside of the case and plug a graphics card in with any sort of heavy heatsink it will lean to that side slightly but it doesnt effect the stability of the system!
So why is this new replacement P8Z68-V motherboard glitching my graphics even on windows unless i stick a roll of sticky tape under it to prop it up a little where the power connectors are? Is my case to blame? It's a small case and i cant use the bottom PCIe slot because of the small size,here it is here.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-052-OK&groupid=701&catid=7&subcat=
One last thing,when i got my "new" motherboard replacement,the time was set to the current date and time,hmm?....im now very confused and replaced almost all parts in my PC,graphics card,motherboard,PSU. Does anybody know whats going on here? Im at my wits end......
lol,im really confused...
lol.
I hope they take it back! Thanks for replies BTW. I guess now i've ruled out the motherboard/chassis as a problem as a replacement board of the exact same model doesnt work either so its got to be my CPU/RAM and if its not that then its the 9800GT and the 460GTX that are both FUBAR since 3 other ATI cards work perfectly on the old board and the new one that im sending back to that evil purple place since it didnt make one bit of difference!
