Hi all
I have a problem with my new build and I’m not sure quite sure how to sort it out. I have a ThermalTake Emelment V case (I know they are not well liked cases but was too cheap to pass), Nvidia 470 GTX and Gigabyte 890GX MoBo. Now my problem is that the backing plate of the gfx card extends below the motherboard, however with the motherboard screwed it place it is almost flush with the back of the case meaning I can’t fit the graphics card. I loosened off the motherboard to see if I could fit the gfx card that way, but 2 problems arose then – only a couple of motherboard mounting holes lined up and if any pressure was applied to the motherboard to fit, it was kicking out the top of the graphics card so that the mounting screw for it couldn’t go in. The room needed is only a couple of mm but hoping someone has a suggestion of how to achieve this couple of mm (preferably not the suggestion to buy a different case)
Thanks, Greboth.
Thanks, Greboth.
