Case modding help
5 Jun 2011
London
Hello.*
I currently have a CM Storm enforcer case. I have 2 Graphics cards and an over-clocked i5 2500k processor the temperature in my case are rather high. The case allows me to have a 200mm fan at the top and one on the front. I can't afford to water-cool my system at the moment but plan to in the future. The aide of the case is clear acrylic. As a temporary fix I want to replace this with a mesh of some kind and have fans on there to aid the copying of the case and my gpu's. Any ideas of the type of mesh or any other materials and where I can get it from to replace the acrylic panel would be hugely appreciated.*
Thanks
Coops1992
Tests have shown that if your case has good cooling already, side fans do not help (in some they hinder) because if you have good airflow from front bottom to top back, this creates a wind tunnel type effect, by adding in side fans you are merely disturbing this airflow and it doesnt help
What temps are you talking here?
