Case Molex Connects To...?
11 Jan 2007
Southend-on-Sea
Nearly there... does the Molex cable (on a Lian Li PC7 Plus that appears to come from the power switch) attach to the PSU? or somewhere else?
Thanks
Simon
Which cable are you talking about, the only wires that are from power switch should be connected to the power switch pins at the bottom of mobo.
I was thinking the same if that's the case connect it up to PSU or remove the molex adapter and just plug the 3 pins fan connector straight onto mobo.
rpstewart said:
I'm guessing it's the power for the front fan. Is it a 4 pin molex socket with only 2 thin wires going to it?
Yes thats it. So can I just connect that to a Molex cable coming off the DVD drive then?
