Case / Motherboard problem
22 Mar 2018
Hi guys, so bought the
https://www.overclockers.co.uk/8pac...0k-4.80ghz-over-170-pounds-off-bu-00y-8p.html
And asked Overclockers via Facebook if the Lian Li 550 case is compatable, they said it was so went ahead and ordered that also.
Just tried to instal it and lined up all the case holes to motherboard etc and the board is like 2 inches back from the IO shield in the case?
I mean, am I doing something wrong that I can’t see?
Have you made sure IO shield has been cleaned ? Normally they leave tags on the port holds from where it's been pressed and when trying to shove the Mobo ports through the shield you get resisstance
