- 3 Jan 2010
Hi Guys, I currently have some strange sort of graphical issues with my PC, seems to show a lot of strange lines as I'm trying to start up the PC, no longer loads past the sort of initial start up point either.
I am looking to get a new case to put my new PC components in when I work out what the issue is and what components need replacing but I've always been bad with cases.
I am after an air cooled case with dust filters if possible (my old haf 932 was a dust magnet), I don't really understand the major differences of the bigger and smaller mobo's so I've ben looking at the bitfenix shadow case but not sure if that motherboard size would be limiting
http://www.overclockers.co.uk/showproduct.php?prodid=CA-145-BX&groupid=2362&catid=1850
budgeting around £100 for case but not looking to spend it unless case is worth it, processor and mobo don't need to be priced up as I'll just get what I want with those.
but I am looking to get a new processor (probably i5 3470 unless 3570 is worth it) but can anyone recommend a good standard gaming case with good air cooling and dust filters? Possibly a mobo that would be good with that case if possible too please but not necessary as I can check that out later.
edit: I notice the corsair 550d is on sale and looks good, not sure if 750d is worth the extra money though (definitely is for looks though
