case needed
22 Mar 2014
Plymouth
Hi there, I need small case that supports full atx motherboard for a build as just got real cheap 4670k + asus ranger mobo so cant go really mini itx unless replace motherboard but it will add cost.
Requirements:
-Support full atx motherboard
-small
-fit noctua nh-d15
- aesthetics to fit female need as this will be a present.
I would be thankful for your help.
NZXT Source 340 is about the smallest ATX tower case you can get. Don't think the NH-D15 will fit though. Do you already have that to hand? Because otherwise you could look at alternate coolers.
Okay thanks guys for all your replies but I ended up with phanteks evlov mini itx in white. This case is beautiful. Just wish front panel was aluminium too :D
