Case options
20 Oct 2005
Hi there
AM looking for case suggestions for my new htpc
If possible I need to fit a full size psu ie 160,mm long
Would like it be be reasonable low in height. Had noticed the Silverstone ML03 but it has a 140 mm limit in the psu.
ML03 is 440w x 105h x 340d
Any other suggestions like the ml03 or similar. Can change to smaller psu if absolutely necessary but already have a Corsair HX 620 modular to use.
Spec to go inside is i3 530/4gb ddr3/gigabyte mobo
Thanks in advance
Van
