Case or aio to change ?
22 Jul 2020
Hello , i have a case gamemax hype black fish tank and a aio bequiet 280mm and its installed on side , problem its when i bought this case and cooler i dont have a hdd 3.5 , now i have a hdd 3.5 and radiator cooler its on back on case and now to install hdd need to put a support from case when i can install 2 hdd but because i put radiator on back hdd dont have space , what recommend ? Change case or aio to take 360 and put on top ...?
You could Get a usb caddy for your 3.5 inch drive or change the aio , the Thermalright frozen note aio are good value if you choose that route .
i told you DONT HAVE SPACE FOR HDD CAGE!!!!!!!!!!!!!!!!!!!!!!!!!
No you said no internal space
That's why I suggested an external solution
And asking for advice
Then shouting at people trying to help you
Doesn't really go down very well in these forums
Why should we waste our time trying to help rude people?
