Case Painting Services
Sem
Sem
18 Oct 2002
London
I'm looking to get a Caselabs SM8 when they resume taking orders and one of the rep says when it returns the two tone option will not be available
so I guess my only option is to get a black case the get the external panels painted i'm currently thinking a titanium grey colour
do you guys recommend any particular companies? preferably in London so i can walk it in and out
will any automotive painter do or should I find one that specialises in aluminium or painted cases specifically?
googling this is not as easy as it would appear either so any advice will be greatly appreciated
Thanks
I don't know if this would be considered a competitor as such, so apologies in advance if so, but Chilled PC offer a case painting service, so you may want to check them out, although they are based in Wales.
Have you considered vinyl wrap? I have done this myself recently on an InWin 303 case, and the results are surprisingly effective. There is a Titanium 3M brushed vinyl that I used myself... this one...
Have you thought about Hydro-Dipping instead of painting?
Google Hydro-Dipping and take a look at all the different finishes that can be done. Some lovely stuff going on via Hydro-Dipping.
I have just put my Corsair Carbide 400C front and side panel in for treatment today with a local company (I got lucky and found a good place only 6-7 miles away from home). As OCUK don't do Hydro-dipping then I don't think dropping you the website will be a problem.
https://www.aquagraphix.co.uk/
You may actually find something a little closer to you if you search the web. They do some lovely snakeskin and carbon films and the finish is amazing. It's also relatively cheap compared to custom painting. I am paying £60 for the side panel and front to be done with this film.....
https://www.aquagraphix.co.uk/wp-content/uploads/2015/06/1427871093GY747.jpg
I have no connection to this company and the first time I went there was today, so I will update with some pictures soon.
Might be worth a shout if you want that custom look :)
I think I've seen that hydro dipping before done on an alloy wheel. It's crazy, the dip it in the liquid, move it around a bit and it comes out with the image on there. Clever stuff. Look forward to seeing how that turns out maonayze, be sure to post some pics when it's done.
I painted the black plastic accents on my H440 myself. 3-4 layers Valspar fast dry project enamel was all that I used and it turned out really well. No experience from doing this before so it's fine for beginners.
