Case & PSU & Cooler - SAVE £36
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
We have teamed up with Cooler Master to allow you to kickstart any new system build.
SAVE £36!
Cooler Master Silencio RC-550 Case and GX 650W Power Supply with Hyper-TX3 Cooler Bundle @ £119.99 inc VAT
Near silent operation and prepared to take on powerful hardware, the Cooler Master Silencio is able to keep high-end setups running cool and quiet. Sound proofing on both side panels assist in vastly reducing noise levels. A sleek mirror finish front panel and clean lines present a minimalistic design aesthetic that speaks to its silent interior. The benefits of elegance and silence, combined with the functionality of built in Super Speed USB 3.0, a multifunction SD card reader, and 3.5" X-dock HDD hotswap all make the Silencio a giant among its kind.
- Includes two 800rpm silent fans (Supports up to three 120mm fans)
- I/O panel provides easy access for users
- High quality foot stand
- Side ventilation holes for better cooling performance
- Dust Filter provided for easy access to wash
- Stylish and Simple design
- Dimensions: 210 x 415 x 505mm
- Motherboard Compatability: MicroATX & ATX
- 5.25" Drive bays x 3
- 3.5" Drive Bays x 7
- 2.5" Drive Bays x 1
- I/O Ports: USB3.0 x 1 / USB2.0 x 1 / Audio x 2 / SD Card reader
- Expansion Slots: 7
- Front Cooling: 120mm x 1, 800rpm silent fan pre-install (can fit 2 x 120mm)
- Rear Cooling: 120mm x 1, 800rpm silent fan pre-install
- Max CPU Cooler Height: 154mm
- Max GPU Length: 427mm
The latest addition from Cooler Master is a range of power supplies that specifically targets the upper mid-range to high-end gaming systems, the Coolermaster GX Series. The Coolermaster GX range of power supplies feature a single powerful +12V rail that has been designed to delivery more than ample power to dual graphics card systems, no matter if you use SLI or CrossFireX.
- Compliance with the latest Intel standard ATX 12V
- Single +12B rail for the most demanding SLI configuration
- High effciency design that meets 80 Plus requirements (85% typical)
- Ultra-silent operation with intelligent 120mm fan speed control
- Multipe protection design (OVP/ UVP / OPP / OTP / SCP)
- High reliability (MTBF > 100,000)
- Double Layer EMI Filter restrains noise and injury to end-user
- Huge bulk capacitor for hold up time > 17ms at full load
- Integrating Active PFC with PWM combo controller not only make PFC higher than 0.99, but also raises efficiency
- Efficent transformer for reducing 5Bsb power loss when the system is at turn-off and sleep modes
- Five Year Warranty
Cooler Master's Hyper TX series has evolved with requirements of current mainstream CPUs. The introduction of Hyper TX3 marks another milestone with Cooler Master's first-ever full compatibility with Intel LGA 1156 socket.
Hyper TX3 is taking basic ideas and simple design while incorporating it with most of the fine points of a decent performing cooler, such as the flexibility to switch from Intel to AMD quickly and easily, the dual fan design to attach another 92mm fan to increase the cooling power. Hyper TX3 also brings back the "original" direct contact heat-pipe design from Cooler Master.
- Flexible mountings for Intel Socket LGA 775/1155/1156 and AMD Socket 754/939/940/AM2/AM3.
- Maximum compatible CPU wattage: over 130W TDP.
- 3 x Direct Contact heat-pipes with aluminum fins to provide excellent heat dissipation.
- Option for adding 2nd fan to increase cooling performance.
- New 92mm PWM fan with wide RPM range and anti-vibration rubber pads.
- Silent CPU cooler at only17 dBA (at minimum speed).
- Easy swappable fan by clips (clips for 2nd fan included).
- Excellent airflow design with compact heatsink dimension.
Only £119.99 inc VAT. (Saving you £35.96)
ORDER NOW
Love the idea Ace Modder, that should get anyone off the ground with an entry to mid-range gaming build, and a good saving too! I like that case as well.
