Case & PSU spec
7 Oct 2005
Hey guys,
I need a case and psu capable of running this spec:
E5200
8800gts 512mb
4gb ram
Needs to be as cheap as possible please guys :)
Many thanks
what cooler do you have? if its the standard one then any case that will fit your motherboard will do, if not then some cases might be too small
I have no budget per se, its just the left over components after a recent upgrade that i wanted to turn into a second PC so i was just looking for the bare minimum needed to get it running safely without it exploding :D
Cooler is a Freezer 7 pro.
