Case question-Does any body make....?
2 Aug 2012
A tower style case where the drive bays come out of the "side" rather than the "Front"?? (If you get my meaning)
(I am wanting a "Shallow" case with front drive access. Height/width is not a problem)
Come out the side without removing the side of the case?
No, I mean the drives are fitted sideways and open/close on the side of the case rather than the front.
Why not make a unit to hold one, maybe remount the original cage and then cut a hole in the side of the case? It's always fun to do some modding!
Your point is well made, Unfortunately I really do not have the time at present but if I cannot find anything "Off the shelf" I will have to consider it.
Lian Li make one, but it is HUGE.
Any chance of a link? I have had a look but cannot find it.
Cheers
Cheers
Sure. I hope you are sitting down, it is one expensive beastie. :p
https://www.overclockers.co.uk/showproduct.php?prodid=CA-564-LL&groupid=2362&catid=187
Also these, but they are still quite deep as they are cube style cases.
https://www.overclockers.co.uk/showproduct.php?prodid=CA-154-LL&groupid=2362&catid=187
https://www.overclockers.co.uk/showproduct.php?prodid=CA-535-LL&groupid=2362&catid=187
Another one is this In-Win 904, the drive bay isnt to the side, but it is accessible from the side as you can see in the picture (second link)
https://www.overclockers.co.uk/showproduct.php?prodid=CA-037-IW&groupid=2362&catid=2277
http://images.bit-tech.net/content_images/2014/01/in-win-904-review/in-win-904-18-1280x1024.jpg
Lian Li PC-X2000
Thinking about it I have seen plenty of smaller cases with no rom drive. Is it an option to buy an external and plug it in when needed?
Lian Li PC-X2000
Possible, but scruffy.
I am basically wanting to make a media PC but because of space limitations I need to put it on a shelf and I don't want it to stick out too much. At a pinch it wouldn't matter if the drive came out to the "side" but it would have been nice to have a "Front" loader (as it were)
How deep is the shelf?
Do you already have the components for the build?
