Case Question
19 Oct 2007
Suffolk
Ok this might be totally n00bish and I apologise now if it is.. but looking at getting a Mozart.. from the pictures looks like it is split down the middle with a space for a motherboard either side??? is this the case? or is it one in bottom one in top?
Also I assume I will have no problems fitting any heatsink in the case as it is so wide?
Edit - (sp)
I dont think many people own such a behemoth, so dont get too upset if you have to go looking instead of waiting for it to come to you. :p
Search this section for "Mozart" and you'll find a couple of great project logs that people have done for that case and you will find your answers. Other than that I'm sure google can find you some technical specs somewhere.
As far as I can remember its not an even split, with one lower section for a standard ATX motherboard and the other lower section for the power supply and maybe another mini-motherboard. The top half is for the drives.
PK!
