Budget?
Corsair 900D, Silverstone TJ11, Coolermaster Cosmos SII, Switch 810, CM Storm Trooper
I could go cheaper if I needed to.
kd
Thanks for your advice, was leaning towards an Antec case either the 902 v3 or the 1200 but I have checked out the Coolermaster Storm Trooper and have ordered that instead.
That was a close dodge, the 902+1200 are ancient designs and show it both externally and internally.
You made a good choice.
Storm Trooper is a good modern case. Has everything you'd need.
Thanks, feel happy that I have made the right choice. My Coolermaster Gladiator was a budget mid tower case that only cost £ 45 and did not fit big graphics cards.
I purchased that simply based on price without taking any recommendations here and it lasted me two years at least.
It wasn't in anyway flashy to look at which I feel the Storm Trooper is.
Its the most I have ever paid for a case but should last me a long time.
