Case Recommendation for CPU and GPU AIO coolers
4 Oct 2017
Would like some recommendations re a suitable case which will take the following without having to remove HDD cages or anything like that.
Kraken X62 CPU cooler ( 280mm radiator )
Aorus GTX 1080 ti Extreme AIO ( 120mm radiator )
Thanks for your help
Alan
System budget is around £3200 ... excluding monitor.
I'll be ordering a system with the new i8700k and an ASUS Z370 X Maximus motherboard. Waiting for it to be released tomorrow. I'd like to minimise fan noise as far as possible, hence I plan to run the X62 in quiet mode.
