Case recommendation request
1 Feb 2007
Hi! I'm looking for recommendations to replace my old Antec 1200, which, while huge, doesn't fit my new AIO radiator. Need to house: Rog strix 490-e, Rog LC 240, 3070, SSD and a couple of HDDs. Was looking at fairly similar/simple design and plenty of future flexibility like enthoo pro 2 or 719, but they might be larger than necessary and I'm not certain if I need any specific requirements to fit the AIO without any modifications. Budget up to about £200..
Thanks in advance for any tips!
Fractal Define 7 is always a great shout; it can do everything.
For something a little different since you have a bigger budget - what about a Sliger Cerberus X? A tight squeeze, but you will save tons of space.
Great, thanks for the quick responses and guidance! I presume the Fractal mid-tower will be fine, as still supports e-atx...? The full towers aren't in stock right now.
Yes both midi towers support eatx motherboard but check specifications and limitations.
For me at first I wanted a bigger case like phanteks p500a p600s but now looking at a more purpose built corsair 4000d etc... That's me.
