- 18 Oct 2002
- Florida/UK
Decided I'm going to get rid of the Vapo LS, had it since before they were released (review sample) and to be honest its given me no end of trouble with the chill control unit failing many times over, basically if I have to turn off my PC for any reason at all, maybe just to take a card out, the compressor won't restart unless its been sat standing for 1hr or more, that and the constant locking up of the chill control causing the compressor to overheat has tried my patience and really I just want some convenience. That coupled with my FX60 that clocks terribly (3ghz on phase... /sigh) I'm really not that bothered by the performance increase.
Looking for a nice case, cost really isn't an issue, ones that have caught my eye are the Lian Li 777, kinda like the different Nautillus look of the case, plus the internal design is fantastic. Other cases that I'm quite tempted by are the Silverstone TJ03 and 07, the 03 is kinda bland but a nice quality case none the less, my reservations about the 07 are simply the issues picked up on review, however if the new revision is now here that helps somewhat. I'm no stranger to cases since I used to work for www.bit-tech.net so have built and seen my fair share of modded cases to boot.
What would you recommend out of those 3? Or perhaps you have something else in mind. I want something special, not a boring steel box. I've had PC70's and 201's before so something a little different would be nice. It's housing an FX60, 2x7900GTX's in SLI (quad SLI next week), 2gb Corsair, 2 raptors, 2 250gb 16mb maxtors, Physx card, X-Fi, 2 DVD RW's and a 1000w PSU.
Looking forward to your suggestions, oh and the case will need to be black unless its particularly special.
